Recording AVIs
PostPosted: Thu Oct 26, 2017 8:39 am
by Cicca
Hi,
if there a chance to record IN-GAME an AVI video...?! I know there the chance to do it from the command line with the option -aviwrite <filename>, but this records the whole session, until you quit the game, and the option "Record Movie", by default activated/deactivated in-game with F12+MAISC, apparently records .MNG files only.....
Thanks for any hint....
Cicca
Re: Recording AVIs
PostPosted: Thu Oct 26, 2017 5:20 pm
or if you're using BGFX, -bgfx_avi_name <filename>
To keep the video as a specific resolution (ortherwise you'll have issues with systems that have variable resolutions), use -snapsize <width>x<height>. Output will be stretched/shrunk to fit.
Do note that AVIs are not encoded, and so, will be very large. You can always re-encode the video with avidemux or similar afterwards, however.
-aviwrite            optional filename to write an AVI movie of the current session
-bgfx_avi_name       filename for BGFX output logging
-snapsize            specify snapshot/movie resolution (<width>x<height>) or 'auto' to use minimal size
Re: Recording AVIs
PostPosted: Thu Oct 26, 2017 7:07 pm
by Cicca
Thanks Barry, but it's not what I'm looking for...what I would like to do, is recording an .AVI video in-game (not since the beginning, with that command line option), just as I can record a .MNG video by pressing F12+MAIUSC to start and stop recording (as defined by default in "Input (General) / User Interface" menu)....any hint...?!
Re: Recording AVIs
PostPosted: Thu Oct 26, 2017 11:11 pm
by BeeJay
Cicca,
You could try using Handbrake to transcode the .mng into a .avi afterwards. I've used Handbrake for lots of transcoding of things like videos we recorded of the kids when they were younger, but I can't definitively say if it will work for .mng format files though as I've never worked with them previously.
Re: Recording AVIs
PostPosted: Fri Oct 27, 2017 4:30 pm
by Kale
Alternative is to use external program like OBS studio.
