Site problems
Cicca
Site problems
Post by Cicca » Fri Feb 03, 2017 4:03 am
Lokks like there are some problems with the DB: the "Leaders" page doesn't show (blank page), while the "loads" returns:
exception! Please copy and paste the text from this page into a mail message to Zwaxy, telling him what you were doing when this happened. And what drugs/medication you were on:
    type:
    value: (145, "Table './mamereplay/allscores' is marked as crashed and should be repaired")
    traceback:
      File "/home/dooglus/replay.marpirc.net/main.py", line 400, in main
        search.do_search(cmd_line)
      File "/home/dooglus/replay.marpirc.net/search.py", line 1012, in do_search
        data = database.select_allscores(where_clauses, joins, sort, maxlines, ignore_string)
      File "/home/dooglus/replay.marpirc.net/database.py", line 246, in select_allscores
        ret = run_query(query, debug)
      File "/home/dooglus/replay.marpirc.net/database.py", line 86, in run_query
        cursor.execute(query)
      File "/usr/lib/python2.7/dist-packages/MySQLdb/cursors.py", line 174, in execute
        self.errorhandler(self, exc, value)
      File "/usr/lib/python2.7/dist-packages/MySQLdb/connections.py", line 36, in defaulterrorhandler
        raise errorclass, errorvalue
Re: Site problems
Post by mahlemiut » Fri Feb 03, 2017 4:46 am
Appears to be back now.
Cicca
Re: Site problems
Post by Cicca » Fri Feb 03, 2017 9:30 am
It is !!! Thanks !!! :D
CrazyKongFan
Re: Site problems
Post by CrazyKongFan » Fri Feb 03, 2017 10:53 pm
looks like it's broken again...doing the same thing as Cicca mentioned in his original post.
Re: Site problems
Post by mahlemiut » Sat Feb 04, 2017 6:45 am
and it looks like it's back again. Would be nice to know what causes it, though. :?
