marp.dat, is there a new file?
Re: marp.dat, is there a new file?
Post by BeeJay » Fri Sep 30, 2016 8:35 pm
I've tweaked the quickly hacked up script to hopefully handle split games in the same way as the Marp logic that used to generate the marp.dat file.
Can you please try this new version and advise if it works better for the split games.
marp.dat.zip
(316.94 KiB) Downloaded 101 times
Post by sawys » Sat Oct 01, 2016 5:17 am
BeeJay wrote:I've tweaked the quickly hacked up script to hopefully handle split games in the same way as the Marp logic that used to generate the marp.dat file.
It seems to work :-)
Good job !! =D> =D>
