BeeJay's simple guide to WolfMame recording/playback
Moderators:mahlemiut, seymour, QRS
Re: BeeJay's simple guide to WolfMame recording/playback
Post by mahlemiut » Fri Mar 04, 2016 5:40 am
Quick update:
Appears to be related to Lua, and affects mostly computer/console drivers more than anything else. There is minimal slowdown in PCE/TG16, about 2-3% only, compared to about 15-20% in the PCE/TG16-based Tourvision driver, however. Still no fix yet.
Post by mahlemiut » Sat Mar 05, 2016 6:22 am
Quickly cobbled together a simple playback toolbar button.
Browse option on playback doesn't do anything yet, I intend to use the file manager (or something similar) to make for an optional easy file selection.
And yes, I am aware than my artistic skills do suck. ;)
OutRunner
Post by OutRunner » Sat Mar 05, 2016 7:32 am
That's very good. Thanks for your investigation and efforts. I will try the next version...
GJTMarper
Post by GJTMarper » Sat Mar 05, 2016 9:04 am
mahlemiut wrote:And yes, I am aware than my artistic skills do suck. ;)
Hey, as long as we can tell what something's supposed to be it's all good. :mrgreen:
Post by mahlemiut » Tue Mar 08, 2016 7:31 pm
Further update:
Slowdowns should be more or less solved now.
Post by mahlemiut » Thu Mar 10, 2016 11:38 pm
Got INP playback option more or less working now.
Do note that it will automatically truncate the path from the filename, since MAME does not accept paths for -playback. So, traversing directories/drives/zipfiles won't be useful.
If you want to try it out, you can clone the source from github, and switch to the 'ui_extra' branch. Or download the source from https://github.com/mahlemiut/wolfmame/tree/ui_extra (click the Download ZIP button). Then compile it. ;)
Post by mahlemiut » Sun Mar 27, 2016 6:38 am
For more general help on using MAME, try here: http://docs.mamedev.org/
It's a little out of date, but should be enough to get anyone started.
OMG Kreygasm
Post by OMG Kreygasm » Mon Jul 18, 2016 9:26 am
I installed 175 last weekend for the IGBY tourney and not being very MAME savvy haven't used much of anything else other than 106 in the past. Just wanted to say thanks Barry, the UI makes it uber easy for noobs like myself to submit for the tourney and am really digging stepping into the present now with my MAME setup.
Cheers
Steve
Barra
Post by Barra » Wed Jul 20, 2016 3:47 am
OMG Kreygasm wrote:I installed 175 last weekend for the IGBY tourney and not being very MAME savvy haven't used much of anything else other than 106 in the past. Just wanted to say thanks Barry, the UI makes it uber easy for noobs like myself to submit for the tourney and am really digging stepping into the present now with my MAME setup.
Cheers
Steve
Bomb out ;)
Andrew Barrow
OMG Kreygasm
Post by OMG Kreygasm » Wed Jul 20, 2016 1:45 pm
Barra wrote:
Bomb out ;)
Fft. Block Out is chit mate. Likitlo
