Doubt with cheats enabled!
empardopo
Post by empardopo »
Hi everybody,
the Marp's rule 2-e says : e) Cheats are not permitted. (although many powerups are) .
Is It valid an uploaded inp with cheats enabled? If you play the inp you can see this
INP it is good?
Greetings!
Re: Doubt with cheats enabled!
You'll probably find the majority of 0.106 and older INPs will give that warning. It only means that the -cheat option was active, it does not necessarily mean that any cheating occured.
The main problem really, is that the GUI had a different default for -cheat, and they often clashed. It's likely to visible for anyone using the GUI, and not for anyone using the commandline.
