IGBY2 game discussion: bgaregga + mustache + bublbob2 (PNS)
Posted: Wed Jul 01, 2015 11:16 pm
by TRB_MetroidTeam
Team, please discuss here about these games:
Battle Garegga [bgaregga (0.117+) / battlega (before 0.117)]
Mustache Boy [mustache (may need t5182)]
Bubble Bobble 2 [bublbob2]
Some links:
IGBY2 page: http://retrocontests.herokuapp.com/#/event/igby2/main
MARP topic: viewtopic.php?f=2&t=15798
Game List (Word) - Settings, DipSwitches, etc: https://docs.google.com/document/d/1QtS ... pXZVg/edit
Game List (Excel) - Controls, etc: https://docs.google.com/spreadsheets/d/ ... edit#gid=0
Streaming List (all teams): https://docs.google.com/forms/d/1vIJJN3 ... 0/viewform
Re: IGBY2 game discussion: bgaregga + mustache + bublbob2 (P
Posted: Thu Jul 02, 2015 1:08 am
by pat33999
There's a great Battle Garegga guide on the shmups forum: http://shmups.system11.org/viewtopic.php?f=5&t=351
Posted: Thu Jul 02, 2015 11:39 am
by hanasu
There used to be a really great one called The Genius of Garegga but those links seem to be broken now.
Posted: Sat Jul 04, 2015 3:51 am
by hanasu
Also, is anyone else having issues with the Garegga DIPs? Rules say extra life 1000k, my only bonus life choices are none and 2000k. Also I have no choice of region (should be Japan). I'm using .162.
Posted: Sat Jul 04, 2015 7:30 am
by BeeJay
hanasu wrote:Also, is anyone else having issues with the Garegga DIPs? Rules say extra life 1000k, my only bonus life choices are none and 2000k. Also I have no choice of region (should be Japan). I'm using .162.
You need to go into the 'machine configuration' menu first, then select Japan, then select the 'reset' option. Then, when you go into dipswitches the 1000k option will be available and already selected. See the attached png for pictures of each step.
Battle Garegga.png (138.35 KiB) Viewed 4887 times
Posted: Fri Jul 17, 2015 3:38 pm
by simpsons99
Mustache Boy level 5 ? How do you finish this level? Is it broken? Or are players just getting lucky and skipping it?
Posted: Fri Jul 17, 2015 3:45 pm
by OMG Kreygasm
U need to utilize the double jump. Hit jump once, then at the apex of your jump, hit jump again. It kind of shows you in the forced instructions when you start your game, but the game is such chit it can't even get instructions to be clear.
Posted: Fri Jul 17, 2015 5:59 pm
by simpsons99
OMG Kreygasm wrote:U need to utilize the double jump. Hit jump once, then at the apex of your jump, hit jump again. It kind of shows you in the forced instructions when you start your game, but the game is such chit it can't even get instructions to be clear.
ty that really helped! :D
Posted: Wed Aug 05, 2015 7:34 am
Quick note: as of MAME 0.164, bublbob2 was moved to bublbob2o, with v2.6O taking it's place.
So, for the purposes of this version (v2.5O): If you're using 0.164, you should use bublbob2o, for older versions, use bublbob2. All should be uploaded to bublbob2o.
