Thanks for all your hard work over the years on this. Much appreciated!
I am unable to compile 0.163 from the source code found at your github page. I am running OS X Yosemite 10.10.4, Xcode 6.4, and Command Line Tools 6.4.
The errors I'm getting are:
I did try searching for this specific set of errors, and came across the following thread at the sdlmame message board:In file included from ../../../../../src/osd/modules/render/drawsdl.c:20:
In file included from ../../../../../src/emu/rendersw.inc:14:
In file included from ../../../../../src/emu/video/rgbutil.h:17:
../../../../../src/emu/video/rgbsse.h:205:13: error: argument to '__builtin_ia32_pslldqi128'
must be a constant integer
m_value = _mm_slli_si128(m_value, shift >> 3);
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.1.0/include/emmintrin.h:832:12: note:
expanded from macro '_mm_slli_si128'
(__m128i)__builtin_ia32_pslldqi128(__a, (count)*8); })
../../../../../src/emu/video/rgbsse.h:205:11: error: assigning to '__m128i' (vector of 2
'long long' values) from incompatible type 'void'
../../../../../src/emu/video/rgbsse.h:220:13: error: argument to '__builtin_ia32_psrldqi128'
m_value = _mm_srli_si128(m_value, shift >> 3);
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/../lib/clang/6.1.0/include/emmintrin.h:899:12: note:
expanded from macro '_mm_srli_si128'
(__m128i)__builtin_ia32_psrldqi128(__a, (count)*8); })
../../../../../src/emu/video/rgbsse.h:220:11: error: assigning to '__m128i' (vector of 2
4 errors generated.
http://forums.bannister.org/ubbthreads. ... 3&page=all
It appears that they are aware of the problem and have fixed it in the latest svn builds of MAME.
Let me know if I can give you any more info, and thanks again for your time!
Dave
