unverified, deletable scores....
kernzy
Post by kernzy »
hi gentlemen!
i have a.... erm... it's not a complaint, but a question.
i have seen many top scores with moderator comments saying "does not play back", or "only plays to this score", etc.
how comes if the scores do not play back to the advertised score is it still in the top position? surely it should be deleted or dq'd?
also, (i have had it a couple of times). the verifier states that the score is not the same as advertised, but it remains "unverified". do you always need 3 viewers to dq it? and why isn't it verified if it's been watched by a moderator? seems there is some housework to be done!seems a bit weird this would be left as it is.
cheers chaps!
kernzy.
:D
Re: unverified, deletable scores....
Because it needs three people to confirm that it doesn't playback before it can be zeroed.
kernzy
Post by kernzy »
ok, Barry.
cool.
when i come across them, i will point then out.
cheers, dude.
8)
