Can't access the main marp replay site.
fraser
Post by fraser »
Just thought i'd see if it's something wrong at my end,as i haven't seen any mention here of problems with the marp website.
fraser
Re: Can't access the main marp replay site.
I was having problems with the site last night and am still having problems today. I chatted with mahlemiut last night and he was aware there are problems. It's not just you.
something happened
: No module named regex
File "index.cgi", line 24, in
import database
File "/home/marp/web/database.py", line 7, in
import regex
Alessandro.S
Post by Alessandro.S »
Has been like that for the last 24 hours or so.
Before the missing regex module error, the DNS entry for marp.retrogames.com wasn't found by my ISP's resolver.
My guess is that it's another one of those ZTNet upgrades that simply screwed something up.
I've sent a note to Zwaxy, hopefully he'll see it in good time.
Ok, from my snooping, Python has indeed been upgraded to 2.5.2, and according to the official documentation, the regex and regsub modules are gone.
They've been depreciated since 2.0, so probably should have seen this one coming...
I've substituted each regex and regsub function for the newer re versions. There seems to be no syntactical differences that affect MARP's code, so I've just changed use of regex.compile to re.compile, regex.match to re.match and regsub.gsub to re.sub. Everythings seems to be working, but let me know if something seems broken.
ZeroMax
Post by ZeroMax »
Hi, i get some errors whilst trying to submit new recordings.
This is what i get....
exception! Please copy and paste the text from this page into a mail message to Zwaxy, telling him what you were doing when this happened. And what drugs/medication you were on:
* type:
* value: No module named regex
* traceback:
File "/sites/retrogames.com/marp/main.py", line 476, in main
import upload
File "/sites/retrogames.com/marp/upload.py", line 1, in
import os, md5, posix, posixpath, re, regex, regsub, string, sys, time
Ok, will look into it a bit later.
EDIT: Fixed, hopefully. Let me know how it works.
kranser
Post by kranser »
mahlemiut wrote:Ok, will look into it a bit later.
It works okay for me now - I can view the main site and the Upload list. Not tried to upload yet.
Kranser.
Can't submit :
File "/sites/retrogames.com/marp/main.py", line 476, in main import upload File "/sites/retrogames.com/marp/upload.py", line 6, in from scores import insert_high_score, update_pos_and_percent_for_tourn File "/sites/retrogames.com/marp/scores.py", line 3, in import regsub, string close failed: [Errno 27] File too large
fraser
Post by fraser »
Same results here !
The upload was only 127KB .
fraser
Udirnel
Post by Udirnel »
Oops, now I get this error message:
"something happened
: (1040, 'Too many connections')
File "index.cgi", line 25, in
database.initialise()
File "/sites/retrogames.com/marp/database.py", line 107, in initialise
reinitialise()
File "/sites/retrogames.com/marp/database.py", line 114, in reinitialise
DB = MySQLdb.connect(host = marp_site.db_host, user = marp_site.user, passwd = marp_site.password)
File "/var/lib/python-support/python2.5/MySQLdb/__init__.py", line 74, in Connect
return Connection(*args, **kwargs)
File "/var/lib/python-support/python2.5/MySQLdb/connections.py", line 170, in __init__
super(Connection, self).__init__(*args, **kwargs2)"
May be it's a normal error according to line ": (1040, 'Too many connections')", but it never happened to me before.
Am I doing anything wrong?
Udirnel
Alessandro.S
Just had this one:
    * type:
    * value: No module named regsub
    * traceback:
      Content-Type: text/html
      something happened
      : local variable 'traceback' referenced before assignment
        File "index.cgi", line 34, in
          main.main(cmd_line)
        File "/sites/retrogames.com/marp/main.py", line 576, in main
          traceback.print_tb(trace)
fraser
Post by fraser »
This is the error i'm now getting when uploading my 417900 score for powj ;
please fill in your 'prefix' name
illegal version
Even though they are already entered, prefix name :afr
