TimeTrial 2013 - R1 - Out Zone (1 loop) [outzone]
Moderator: giro-X
giro-X
Re: TimeTrial 2013 - R1 - Out Zone (1 loop) [outzone]
Post by giro-X » Fri Nov 01, 2013 1:46 pm
Made over 300 tries (after two days of pattern study), still didn't come up with something satisfying my desires.
I'm going through another big session, if I don't get stage 4 completed or better I'll have to upload stage 3.
kernzy
Post by kernzy » Fri Nov 01, 2013 2:54 pm
same here. damn hard!
giro-X
Post by giro-X » Fri Nov 01, 2013 3:22 pm
RAX wrote:The method I use to calculate the framecount is from appearance of the character (blinking yellow from under the mothership) to the beginning of the explosion of the last defeated boss.
Okay then, I was extending it a bit :) I'll use it eventually in a future uploading.
I calculated from appearance of lives and energy indicator at the top, to the appearance of STAGE XX completed. So yeah, I counted some extra frames.
36121 frames, according to the previously described method, stage 5 completed.
Very awful time for being stage 5, I didn't get speed up before almost end of stage 3 and lost my first life at stage 4 (again!).
outzone_s5f36121_giroX.zip
(432.4 KiB) Downloaded 305 times
Post by sawys » Fri Nov 01, 2013 4:17 pm
stage 3 ok - 19246 frames if i'm correct.
outzone-sawys-stage 3 ok-w150.zip
(229.04 KiB) Downloaded 282 times
BDF
Post by BDF » Fri Nov 01, 2013 4:48 pm
I tried running and finaly finished stage 3 mproving my frame number.
I also understood how to count frame by frame.
RAX wrote:when in pause SHIFT-P advance frame-by-frame.
17162-460=16702
Not sure i will finished stage 4 before the end.
bdf_outzone_428910_w150_st3.zip
TT2013 - outzone stage 3
(240.53 KiB) Downloaded 380 times
Jerome
Post by sawys » Fri Nov 01, 2013 5:00 pm
Stage 3 ok - 17790
outzone-sawys-stage 3 ok-17790-w150.zip
(276.4 KiB) Downloaded 253 times
Post by sawys » Fri Nov 01, 2013 5:38 pm
stage 4 ok - 28790 (473-29263)
Most stupid is die with a lot of bomb ^^
outzone-sawys-stage 4 ok-28790-w150.zip
(444.26 KiB) Downloaded 265 times
franco.benedetti
Post by franco.benedetti » Fri Nov 01, 2013 8:55 pm
6th mission completed, though not that fast, about 54600 frames :(
giro-X
Post by giro-X » Fri Nov 01, 2013 10:21 pm
franco.benedetti wrote:6th mission completed, though not that fast, about 54600 frames :(
Hey man, are you sure the ZIP you loaded is correct? 22 bytes only it says, it's exactly the byte dimension on an empty ZIP :(
Kudos for beating the sixth stage :D you can be of company to me there, with nii-san. The unbeatable nii-san...
39500 frames [~39910 - 461] more or less, this is because I was lazy to verify which was the first frame with boss explosion (it died with a bomb... so explosion over explosion...)
First life lost at stage 6. It was a stupid death so I expect to be playing again until I get a no miss for the first 6 stages at least. In my practice of the first two days I wasn't able to do a complete loop with no miss.
giroX_outzone_st6_39500fr_w150.zip
(444.2 KiB) Downloaded 388 times
franco.benedetti
Post by franco.benedetti » Fri Nov 01, 2013 11:18 pm
giro-X wrote:Hey man, are you sure the ZIP you loaded is correct? 22 bytes only it says, it's exactly the byte dimension on an empty ZIP :(
oops...
i didn't zip it cause was practicing some dk, pacman and space invaders in the meantime :)
in addition attachment over 512k are not allowed so:
https://www.dropbox.com/s/cbguc7fsfl1ol ... olf150.zip
kernzy
Post by kernzy » Fri Nov 01, 2013 11:52 pm
that was great, mate.
is it quicker to go straight up then diagonally? seems the same to me.
never done speedruns before. if i don't shoot most of them, they turn around and shoot me!!
CrazyKongFan
Post by CrazyKongFan » Sat Nov 02, 2013 1:19 am
OK, I finally got thru boss 2. I thought we were counting when you started getting points, but I guess it's as soon as the boss dies. I'm not 100% sure on the frame, since I used a bomb to finish him off, but I think it's 12592. Started at 647, for a total of 11945. Gonna keep trying tonight.
FAO-tt2013-11945-2boss.zip
(173.82 KiB) Downloaded 293 times
RAX
Post by RAX » Sat Nov 02, 2013 5:09 am
I apologize for not having updated yesterday, I've been away from home. Now I'll download and replay everything new.
I will also give a final word about the reference time issue that TRB noticed (It was seen during KO too)
Post by BeeJay » Sat Nov 02, 2013 8:36 am
Finally a game where I managed to beat the 3rd boss.... definitely rusty on the game playing these days!!
Stage 03, 25617 frames.
outzone.zip
(326.78 KiB) Downloaded 282 times
Post by Phil Lamat » Sat Nov 02, 2013 11:44 am
No time to play, my son is at the hospital ...
First try today, only stage 1 clear, frames around 7700
outzone=st1_w150.zip
(99.44 KiB) Downloaded 366 times
