Two questions about two games..
Post by QRS » Fri Jan 19, 2001 12:30 pm
Well, I have two questions about two games:)
1.Crazy Kong:
I have already talked with Ben Jos on Irc a few times about this..
I remember when I played this game in the arcade that you could get
some kind of "rose" ors something when you jumped over a certain number of barrels on hte 25m stage. I have tried it on mame but I can´t see any "roses" at all.. Question: anyone that has seen this? On mame or on the real machine?
2.Marble Madness:
Once I have seen (in a game magazine I think) that you can acess a sectret level in Marble madness called "the water level" or likwise..
I may be wrong of course but I think I have seen it myself a long time ago or even tested it myself.. It´s also possible that I mix M.M up with "gyroscope" (c64 game) but I don´t think so..
It had something to do with making a long "jump" out from a ledge somwere on the first or second level I think.. I talked with Lordgaz about it but he had no knowledge about any sectret level.
Please tell me if you know anything about this, OR if those drugs I used in my youth makes me dreaming about unreal things:)
Anyway.. thanks for listening:=)
Regards
qrs@telia.com
Post by AL » Fri Jan 19, 2001 12:30 pm
Never seen or heard of the CK 'roses' , but somewhere back in time, I
too heard of a secret level in MM. Never seen it , but probably read
about it somewhere. And that bit about a long jump off a ledge sort
of rings a bell.....?
As for the drugs , I`d be more worried about the ones your taking
nowadays....( aren`t the prices scandalous btw? :))
alexweir@indigo.ie
Tommi
Post by Tommi » Fri Jan 19, 2001 12:30 pm
QRS, there is a secret level in MM, water level. Not Arcade version,
but some home system conversion(don't remember which/maybe all). I've
only seen a picture in net. That conversion had awful graphics. It
was a rumour that arcade version/original had it too, but I (as many
other)think that it's not true.
The trick to enter is(I read this somewhere): At level 1(practice)
jump into left side bonus numbers. Then you'll have to wait at exact
spot near numbers for a while, then you get into water level.
Maybe if you use enough drugs, you can find your own "secret
levels"...
http://www.bodenstaendig.de/marble/
http://www.classicgaming.com/rcatt/tips ... l#mmadness
http://www.cc.utah.edu/~ss7255/main.html
http://netrover.com/~timt/classics/m/marblemadness.html
tiihoto@hotmail.com
wow thanks! At least the secret level is MM was not a dream!
and it certainly rings a bell when you are talking about the
waterlevel Tommi! well, I know for sure now I have seen the level,
but I don´t know if I ever played it on console, or any other version
than the arcade..I wonder were I have seen it then.. maybe it was on
the arcade after all..
About the "roses" in ckong: I think you got it when you jumped over 3
or more barrels in a row, and one of those had to be a dif kind of
barrel.. The version of ckong I played was the falcon (japan set1)
version. You didn´t get any points at all for the "rose" (except the
300 points or whatever for jumping over the barrels:) It just showed
up in the upper left corner I think OR maybe it was over the barrels
you jumped over.. I don´t remember..
anyway, anyone else who knows??
Regards
qrs@telia.com
TJT-170540_at_arcade
Post by TJT-170540_at_arcade » Tue Jan 23, 2001 12:30 pm
QRS, incase you didn't know, you might want to look at my Marble
tricks at tricks-section, funny things you can do with a trackball :)
tiihoto@hotmail.com
Jamie McLaughlin
Post by Jamie McLaughlin » Wed Oct 10, 2001 12:30 pm
The marble madness secret level was on the C64 and 8-bit Apple
versions of the game. It might be on the Amiga version (try it and
see!). It is certainly not in the Arcade original.
Precise Instructions to access the C64 Water Maze can be found at
this URL:
arnold.c64.org/~minstrel/ea/marble.html
HIP00JJM@Sheffield.ac.uk
