The big list of games with problematic playback
Post by The TJT » Thu Jun 08, 2006 10:08 pm
Cybergoth wrote:Ok, thanks. I just submitted a small test game :D
That was small yeah. That small one playbacked fine here, I warn that often inps playback for few minutes and then playback misses sync. Your score was 3428... 4 and 9 look a bit same in the Tron world :)
Chufoglu
Post by Chufoglu » Fri Jun 09, 2006 1:58 pm
I have problems with the inputs in Super Punch-Out, my inp´s don´t work in wolfmameplus. I don´t worry too much because i can´t make the record, i can make around 300.000 points what means be the fourth or so in the ranking, but i put it in order to make people know this problem with Super Punch-Out
Cybergoth
Post by Cybergoth » Fri Jun 09, 2006 4:11 pm
Ok, fixed the score. I'll try achieving a better score - I only just started playing it, still tweaking controller settings :)
saulonpb2
Re: The big list of games with problematic playback
Post by saulonpb2 » Sun Sep 16, 2012 9:30 pm
please verify the scoreboard i ve hear that some people are using softwares to modify some games, using turbo macro, desacelerating frames, augmenting the scores above the normal.
The Expert keyboard
Post by mahlemiut » Sun Sep 16, 2012 9:49 pm
saulonpb2 wrote:please verify the scoreboard i ve hear that some people are using softwares to modify some games, using turbo macro, desacelerating frames, augmenting the scores above the normal.
Can you provide examples on INPs doing this, or at least expand on this somewhat? MAME's speed is recorded in the INP as standard.
Post by Chad » Mon Sep 17, 2012 11:43 am
we do and have checked for and zeroed scores for doing this. We can't check all recordings, so if you suspect point out the recording (like Barry suggests) and we will check it.
saulonpb2
Post by saulonpb2 » Sun Dec 16, 2012 3:20 pm
some one else verify street fighter 2 ce, romset sf2ceeea, please.
The Expert keyboard
saulonpb2
Post by saulonpb2 » Thu Jan 10, 2013 6:09 pm
verify and remove sf2ceeea if wrong, i ve verified here the score 1642300 onlçy can be reached with the computer almost stopped, without movements. i tested here in my home.
The Expert keyboard
Post by GHEMANT » Tue Jan 28, 2014 3:46 am
saulonpb2 wrote:verify and remove sf2ceeea if wrong, i ve verified here the score 1642300 only can be reached with the computer almost stopped, without movements. i tested here in my home.
Please explain better the problem.
INNUENDO
Post by INNUENDO » Wed Nov 19, 2014 4:09 pm
Splatterhouse on early versions. Loses sync.
Kale
Post by Kale » Sun May 28, 2017 12:20 pm
http://replay.marpirc.net/inp/1/b/0/prf ... olf183.zip
Can't get a coin inserted if fast forward key is pressed.
Otherwise playbacks to the advertised score, maybe a common issue with Deco Cassette System games?
Cicca
Post by Cicca » Wed Sep 13, 2017 5:16 am
HI all,
Did anyone eventually sorted out the well know desynch issue playing back alibaba...?!? I made a bounch of test, with latest (0.189), intermediate (0.163), and older (0.106) versions of both MAME and WolfMAME, with any combination of switches (-noautoframeskip, -fs 0, etc etc), which should be, anyway, if I'm not wrong, the default values.....but always had no luck....after the first death, it completely desynchs....
Any hint...?! Thanks....
Kale
Post by Kale » Thu Sep 14, 2017 5:49 pm
Cicca
Post by Cicca » Thu Sep 14, 2017 8:49 pm
WOW !!! Looking forward... 8)
