T15 - Submissions (for forum), scoreboard, etc.
Moderator: giro-X
giro-X
Post by giro-X » Sat Sep 17, 2016 12:53 pm
Use this thread to submit your scores for the tournament.
You can also submit the INPs to MARP, just add the label "T15" in the replay description.
To check quickly which are the latest T15 uploads on MARP, you can use this link:
http://replay.marpirc.net/index.cgi?mode=search&table=y&per_game=99&short=(shangon-jnr,blocken,kuniokunb,lrescue,wboy2,phoenixa)&desc=t15&sort=short&maxlines=600
Remove the string &desc=t15 from the URL to see also all scores not for tournament.
The string &sort=short will display results sorted by game name. Change it to &sort=date_rev if you want to see the newest scores at top, instead.
ALL YOU NEED FOR THIS TOURNAMENT
WolfMAME 0.177
Romsets: blocken, kuniokunb, lrescue, phoenix, phoenixa, renegade, shangon, wboy, wboy2
Samples for Lunar Rescue (optional, but, it's a little bit silent if you don't use them)
Countdown to end: http://www.timeanddate.com/countdown/ge ... erif&csz=1
Ranking: https://docs.google.com/spreadsheets/d/ ... sp=sharing
The ranking will be updated more or less once a day, in the days I can.
DELETE NVRAM BEFORE RECORDING!
Since this mistake keeps on happening too frequently, it's like we have to underline it again.
SUGGESTION (for Windows users): prepare a *.bat file for both playing/training, recording, playback; just like those you already find in the Mame folder (playback; record), you can modify those. In each of them, it is important that you have the parameter
-nvram_directory NUL
If you ALWAYS use these batch files, you will never have to delete the NVRAM folder. Otherwise, first delete the NVRAM folder AND THEN start recording.
Here's some examples of what I mean. This must be the text written on the *.bat files.
For playing:
mamearcade -nvram_directory NUL
For recording (in this example, Phoenix on Centuri set 1):
mamearcade phoenixa -record phoenixa.inp -nvram_directory NUL
To playback (change name accordingly to file you have):
mamearcade phoenixa -playback phoenixa.inp -nvram_directory NUL
With the latest MAME interface, you can already decide to record or playback from there without using a *.bat, BUT, if you simply double click on mamearcade.exe you don't give it the parameter of no NVRAM folder, and each time you play something, it will create NVRAM files. Hence why I insist. You don't want to waste time, right? :wink:
ABOUT GAMES
Game #1 - Phoenix (Centuri, set 1) [phoenixa]
Shooter, 1980 Amstar (Centuri license)
To play this clone, you also need the parent: Phoenix (Amstar) [phoenix]
Game #2 - Wonder Boy (set 2, 315-5178) [wboy2]
Platform, 1986 Escape (SEGA license)
This is not the second chapter, it is a clone of the first chapter.
So, to play this clone, you also need the parent: Wonder Boy (set 1, 315-5177) [wboy]
Game #3 - Lunar Rescue [lrescue]
Maze, 1979 Taito
This game has audio samples, which do not go in the same directory of roms.
Known bug: One free credit is awarded at first landing.
Game #4 - Nekketsu Kouha Kunio-kun (Japan bootleg) [kuniokunb]
Fighter 2.5D, 1986 Technos Japan (Taito America license)
To play this clone, you also need the parent: Renegade (US) [renegade]
This is how Renegade looks, actually. Kunio-kun has different sprites, and you don't get to kiss the girl at the end.
Game #5 - Super Hang-On (sitdown/upright) (unprotected) [shangon]
Driving, 1987 SEGA
We're playing JUNIOR COURSE ONLY, so, if uploading to MARP, please submit your replays to shangon-jnr
Game #6 - Blocken (Japan) [blocken]
Breakout, 1994 Visco / KID
Known bug: when finishing the fourth course, you get a cell testing screen instead of credits. (This won't influence the game experience, the definitive score can be read when ending last stage)
Since I generously :roll: gave you a game that is totally in Japanese, even if you can understand everything by playing, I will shortly describe what is needed.
The match can end in three ways: a player loses his ball; a player gets crushed by advancing blocks; a player clears the field.
There are 4 courses. Course at the top, shortest. Course at the bottom, longest. The enemies and their pattern don't change, you only decide how many stages you want to play. Quite obvious then to state you should pick the 4th course, for more points.
The attack button is used to send lines of blocks to enemy. If you have MAX Energy, your ball will also be able to break all blocks in the way, for a short time.
RESUME OF RULES
-All games are to be played with default MAME settings. (Ask if you need help to set them properly if you changed them on playing)
-Keep average recording speed as near as possible to 100% (in other words: don't change it at all)
-For games with no ending (Phoenix, Lunar Rescue, Nekketsu Kouha Kunio-Kun), score considered will be what you reach at 2 hours of play, if the replay is longer. (Rule for this tournament only. 2 hours instead of another span of time is a personal choice)
-No macro, autofire, multiple buttons for same action, and all that stuff that is forbidden in MARP. We got enough cheating in the past, thank you :?
-First credit only
-No recording can be uploaded 24 hours after you started to record it. If this period is violated, then that person's score for that game will be changed to zero.
For any question, I'm here anytime.
Confirmation of a score for the tournament doesn't imply confirmation in MARP, and viceversa.
Have fun! :D
giro-X
Re: T15 - Submissions (for forum), scoreboard, etc.
Post by giro-X » Sat Sep 17, 2016 12:54 pm
We haven't started yet, though. Today's only the announcement of the games.
The tournament starts in a few hours. Check the countdown. http://www.timeanddate.com/countdown/ge ... erif&csz=1
Don't start recording before the tournament starts, too.
giro-X
Post by giro-X » Sat Sep 17, 2016 9:31 pm
The tournament starts NOW :)
I'll be updating all the stuff needed.
Important: the day initially indicated in the Rules thread as the end of tournament was miscalculated. Since it's 6 weeks long, it will end on 29th of October, not 22nd.
My apologies.
simpsons99
Post by simpsons99 » Sun Sep 18, 2016 12:48 am
where is the sign up ? or do i just submit scores and i am entered?
Arcade Game Scores
giro-X
Post by giro-X » Sun Sep 18, 2016 11:52 am
Message to player: "Dirty"
Please be careful, the string to write is T15, not TG15. I take it should be a tournament submission, so for now I'll add it.
simpsons99 wrote:do i just submit scores and i am entered?
This. :wink:
As one starts submitting, I'll add them to ranking.
Post by Phil Lamat » Tue Sep 20, 2016 5:08 pm
Mmmm
Submissions seem broken ; anyone else have problem to submit ?
For info I have 1229690 on blocken ...
Post by sawys » Tue Sep 20, 2016 5:12 pm
Phil Lamat wrote:Mmmm
Idem for me...
Message is :
exception! Please copy and paste the text from this page into a mail message to Zwaxy, telling him what you were doing when this happened. And what drugs/medication you were on:
type:
value: (145, "Table './mamereplay/allscores' is marked as crashed and should be repaired")
traceback:
File "/home/dooglus/replay.marpirc.net/main.py", line 479, in main
upload.do_upload(cmd_line)
File "/home/dooglus/replay.marpirc.net/upload.py", line 278, in do_upload
position = insert_high_score(short, score, prefix, version, 0, the_udt, md5_dir + "/" + basename, desc)
File "/home/dooglus/replay.marpirc.net/scores.py", line 47, in insert_high_score
if (not database.select_allscores_count_for_short_name(short)):
File "/home/dooglus/replay.marpirc.net/database.py", line 311, in select_allscores_count_for_short_name
return run_query(query, debug)[0][0]
File "/home/dooglus/replay.marpirc.net/database.py", line 86, in run_query
cursor.execute(query)
File "/usr/lib/python2.7/dist-packages/MySQLdb/cursors.py", line 174, in execute
self.errorhandler(self, exc, value)
File "/usr/lib/python2.7/dist-packages/MySQLdb/connections.py", line 36, in defaulterrorhandler
raise errorclass, errorvalue
Post by sawys » Tue Sep 20, 2016 5:13 pm
I have 6.452.530 on shangon-jnr
shangon.junior-stage 5-6452530-w177-3m.zip
(123.75 KiB) Downloaded 129 times
Post by sawys » Tue Sep 20, 2016 6:00 pm
354.120 on blocken
blocken.expert-stage 3-354120-w177.zip
(186.32 KiB) Downloaded 145 times
Post by Phil Lamat » Wed Sep 21, 2016 3:01 am
Ok it looks fixed
Note that if you have tried to submit yesterday, your inp is somewhere even if not appearing in scoreboard.
So if you want to resubmit you will have to put a higher score, then edit it back to correct score
Post by Phil Lamat » Wed Sep 21, 2016 3:03 am
My score for phoenixa above (as I have a better score on Marp)
phoenixa=209891_w177.zip
(94.32 KiB) Downloaded 172 times
giro-X
Post by giro-X » Wed Sep 21, 2016 2:21 pm
All updated.
Friendly hint / reminder to all current and incoming participants.
For uploading scores on first half of tournament, you get a multiplier. The multiplier will change if you re-upload a new score, always depending on which week it belongs to.
Be careful when uploading new scores, in the eventuality that your new high score is slightly better than the previous, and the multiplier changed to a smaller amount. Uploading a too low improvement may result in a loss of points.
A practical example:
Top score (not yours) is 2.000.000 pts (worth 100 TP + multiplier).
Your best so far was 1.250.000 pts with a 24% multiplier (worth 76.88 TP).
Imagine that at 3rd week you get a new high, 1.350.000 pts. If you upload it, since the multiplier went down to 8%, your TP total would be 72.36. A loss of 4 and half points.
Thus said, if you need assistment, or you would like to have a sort of document ready-to-use... whatever, let us know. Just be careful about sudden "surprises". :wink:
Cicca
Post by Cicca » Wed Sep 21, 2016 8:31 pm
My first scores:
lrescue = 14350
blocken = 71000
shangon-jnr = 4547520
shangon_4547520.zip
(109.33 KiB) Downloaded 139 times
blocken_71000.zip
(184.23 KiB) Downloaded 142 times
lrescue_14350.zip
(271.32 KiB) Downloaded 133 times
giro-X
Post by giro-X » Thu Sep 22, 2016 12:45 pm
Seems like there's still the same error going on. Players can obviously still load here on forum, for tournament, but I wonder if we should extend everything by one day, to recover "one" lost day for uploading replays.
Waiting opinions.
simpsons99
Post by simpsons99 » Thu Sep 22, 2016 3:29 pm
why is it always during this event every year Marp is messed up and broken?
Arcade Game Scores
