T14 Rules
Moderator: giro-X
Re: T14 Rules
Post by mahlemiut » Thu Nov 05, 2015 2:56 am
PG3 wrote:
wolfman24 wrote:if there is a problem with the game or you are having problems recording you can use .106
- 0.150: RanaElia added Violent Storm (ver EAC). Renamed (viostorm) to (viostormeb).
http://www.progettoemma.net/gioco.php?game=viostorm
Which means you should be uploading your scores to viostormeb (game list clearly states "version EAB"). And if you're using MAME 0.150 or later, you should be recording viostormeb, too.
wolfman24
Re: T14 Rules
Post by wolfman24 » Thu Nov 05, 2015 3:59 am
oops that was my bad it was suppose to be EAC the parent rom. sorry about the confusion and thanks for the catch mahlemiut
Re: T14 Rules
Post by mahlemiut » Thu Nov 05, 2015 4:23 am
wolfman24 wrote:oops that was my bad it was suppose to be EAC the parent rom. sorry about the confusion and thanks for the catch mahlemiut
In that case, then, you can't use 0.106, since version EAC doesn't exist in 0.106.
PG3
Re: T14 Rules
Post by PG3 » Thu Nov 05, 2015 6:09 am
17
Re: T14 Rules
Post by mahlemiut » Thu Nov 05, 2015 7:49 am
You need to provide the game shortname to the commandline. Providing nothing tells MAME there is no selected driver, and will use the built-in menu to select a driver.
You might also want to set a value for inpview in mame.ini, although it should revert to 0 (meaning disabled) not an empty string.
Re: T14 Rules
Post by Phil Lamat » Thu Nov 05, 2015 11:32 am
wolfman24 wrote:Is anyone able to playback PG3 violent storm score? It desync for me at the 2nd boss. Is there any playback problems with the game in the past?
Desyncs for me at 1,339,400
Re: T14 Rules
Post by Phil Lamat » Thu Nov 05, 2015 11:38 am
mahlemiut wrote:You need to provide the game shortname to the commandline. Providing nothing tells MAME there is no selected driver, and will use the built-in menu to select a driver.
Barry is right.
Try :
mamearcade viostorm -record viostorm.inp
and
mamearcade viostorm -pb viostorm.inp
Re: T14 Rules
Post by Phil Lamat » Thu Nov 05, 2015 11:39 am
wolfman24 wrote: oops that was my bad it was suppose to be EAC the parent rom. sorry about the confusion and thanks for the catch mahlemiut
So tourney is on the new "viostorm" (EAC), right ?
EDIT :
I see you've corrected "EAB" to "EAC" in the game list, so forget my question
CrazyKongFan
Re: T14 Rules
Post by CrazyKongFan » Thu Nov 05, 2015 12:06 pm
Is it too late to register now that it's started?
simpsons99
Re: T14 Rules
Post by simpsons99 » Thu Nov 05, 2015 1:31 pm
I had no clue this had started .. I never saw a sign up or anything .
Arcade Game Scores
wolfman24
Re: T14 Rules
Post by wolfman24 » Thu Nov 05, 2015 2:41 pm
CrazyKongFan wrote:Is it too late to register now that it's started?
can still sign up now just start submitting scores and I will add you to the scoreboard
wolfman24
Re: T14 Rules
Post by wolfman24 » Thu Nov 05, 2015 2:42 pm
simpsons99 wrote:I had no clue this had started .. I never saw a sign up or anything .
yeah that was my bad I didn't post the signup intil about the 25th you can still join in though
simpsons99
Re: T14 Rules
Post by simpsons99 » Thu Nov 05, 2015 3:05 pm
confused where is this sign up? :o
Arcade Game Scores
simpsons99
Re: T14 Rules
Post by simpsons99 » Thu Nov 05, 2015 3:10 pm
found it
I have Zupapa score already .. Great choice though
2nd
special rules Zupapa!
(zupapa) simpsons99 (@) 12 Aug 11
23:19:56 4,985,200 (edit) wolf106
get MAME
Arcade Game Scores
wolfman24
Re: T14 Rules
Post by wolfman24 » Thu Nov 05, 2015 3:17 pm
simpsons99 wrote:confused where is this sign up? :o
you can just start submitted scores and I will add them to the leaderboard
