T14 Rules
Moderator: giro-X
Re: T14 Rules and Voting
oy dax
1. Game list will appear on the 1st day of the contest November 2nd. I can give a zip file with the roms if needed
2. Contest is a combination of Double and Singles if you want to play only single you will only count toward that scoreboard, if you are playing doubles you will count toward both double and singles scoreboard.
3. The scoreboard is being worked on and Registering hasn't been opened yet for the scoreboard, so if you are going to play in it make a post or send me a pm to let me, so i can get a headcount
- Button Masher
Final Game list available for looking at ?
game list will be posted on monday
I want to play
game list and dips
http://docs.google.com/document/d/1goFV ... sp=sharing
can submit scores in the thread here, thru marp site, or email me it at lupoman24@gmail.com
if you didn't register for the contest you can still register
good luck everyone
good luck everyone
Re: T14 Rules
Is anyone able to playback PG3 violent storm score? It desync for me at the 2nd boss. Is there any playback problems with the game in the past?
Re: T14 Rules
I was looking at the scoreboard it looks like viostormj doesn't have playback issues. can anyone confirm this?
Re: T14 Rules
scores spreadsheet
https://docs.google.com/spreadsheets/d/ ... sp=sharing
single leaderboard
double leaderboard
single leaderboard
double leaderboard
Re: T14 Rules
For info :
0.134u2: Team Japump added New Rally X (Namco 1981). Changed description of clone 'New Rally X' to 'New Rally X (bootleg?)'. Renamed (nrallyx) to (nrallyxb).
So I've moved all pre-135 inp to nrallyxb, and edited special rules to use 135 or later for parent rom
Re: T14 Rules
so far two days in and the leaderboards are
doubles
dax team in the lead with 8 points
singles
dax in 1st with 60 points
Phil Lamat in 2nd with 14 points
doubles
singles
Re: T14 Rules
you can use .166 or .167 as the current verisons if there is a problem with the game or you are having problems recording you can use .106
