Page 1 of 6
T10 has begun!
Posted: Thu Dec 07, 2006 8:37 pm
Have fun!
Click the tournament link in the top frame for the main T10 page.
More game info is here - http://mahlemiut.marpirc.net/t10/t10_games.html
Posted: Fri Dec 08, 2006 5:25 am
by LN2
nice web page Barry. I love how you show the MARP, TG, and Gamest high scores for each title.
For fact though... top score for Mario bros here at MARP was playing at MAME default setting...which is difficulty=easy. It is given in the description even.
The second place score here( :P ) is played at TG settings. It would not surprise me if a couple are able to top my currently posted score here at TG settings. I see george has already gotten very close. hehe
The game plays easier at that default setting versus TG settings you are using for T10.
A simple rules question...
To encourage good sportsmanship, no recording can be uploaded 48 hours after you recorded it.
Is that supposed to read that no recording can be submitted beyond 48 hours after you recorded it? IOW, submit it within 48 hours after finishing play...
Posted: Fri Dec 08, 2006 11:49 am
by Chufoglu
Some Gamest records seem to be impossible. 2.000.000 in Darkstalkers?
Posted: Fri Dec 08, 2006 12:51 pm
by destructor
Hehe, I have the same problem with Rockman 2. Look at comments in my score.
I still didn't found where is leeching spot or something.
Posted: Fri Dec 08, 2006 4:42 pm
LN2 wrote:A simple rules question...
That's right, to help avoid sandbagging.
Posted: Sat Dec 09, 2006 12:51 pm
by jbd41
How does one change the settings on Wacko?
Posted: Sat Dec 09, 2006 2:53 pm
by Weehawk
jbd41 wrote:How does one change the settings on Wacko?
From the dipswitch menu, set service mode "on", reset game using dipswitch or F3. Go to number 5, "Machine Setup".
Posted: Sat Dec 09, 2006 6:54 pm
You should use either the Service Mode DIP Switch or F2 to restart, F3 typically isn't recorded in an INP as it is a function of MAME rather than as a result of changing an input port.
There certainly used to be a way in the source to mark an input as a reset, but I thought that was removed quite some time ago. I'll have to look through the source at some point.
Posted: Sat Dec 09, 2006 8:42 pm
by LN2
mahlemiut wrote:You should use either the Service Mode DIP Switch or F2 to restart, F3 typically isn't recorded in an INP as it is a function of MAME rather than as a result of changing an input port.
yes, at least going back to 0.56 the F3 presses are not recorded.
F1 and F2 presses are recorded so using those to negotiate service mode is fine in a recording. Note you will have to repeat the sequence for each recording when changing settings through the actual game's service mode.
Posted: Mon Dec 11, 2006 5:03 pm
Important rule change:
Settings for Popeye have been changed to "extend at 50,000", as the TG setting of 40,000 is not possible on this revision. Most players seem to be using this setting, so this shouldn't affect most people.
Posted: Thu Dec 21, 2006 12:06 am
by Novice
Chufoglu wrote:Some Gamest records seem to be impossible. 2.000.000 in Darkstalkers?
Rompers Gamest record holder visited MARP.
and uploaded his play 3-4 years ago.
did you realize it?
HE WAS "GREEN WOODS."
Posted: Thu Dec 21, 2006 12:33 am
by Weehawk
did you realize it?
http://marp.retrogames.com/inp/noo_romp ... mame60.zip
Wasn't bad at Tower of Druaga either:
http://marp.retrogames.com/inp/noo_todr ... mame60.zip
Posted: Fri Dec 22, 2006 7:11 pm
by LN2
that is truly masterful level of play for the game if played legit(no save states used, or pausing etc.)...although the leeching gets semi-borderline at spots. It was still awesome to see the game actually has an end with apparently a 2.2 million bonus given at the end(?). 2.2 million? that is an odd number.
I couldn't help but notice after playback it shows the average fps was 3.3!
hmmmm.... if that showed 60 fps then I wouldn't question it.
Posted: Fri Dec 22, 2006 8:18 pm
My guess is 100k x lives remaining.
Posted: Sat Dec 23, 2006 8:30 am
by LN2
oh, that sounds very possible....means those 1-up combos he got along the way are very valuable.
I didn't think he got that many though....would have to watch it and count them up.
how often are extra men awarded? I see no settings are accessible for the game....odd.
